BoCRon
So I'm now researching the mini split. Assuming I get the mini split the ceiling mount electric heater I bought for the garage will get installed in the basement shop for supplemental heat.
I'm a bit confused about the electrical requirements needed for a mini split. I've seen all sorts of numbers and honestly have no idea which is the way to go.
Some say 115v, some 208v, or 220v.........
Also, where the unit actually needs the power is not clear to me. Does the power need to be outside where the condenser is located or inside near the air handler?
So if I go with 115v (which is standard I'm guessing) then the unit will cost more to run,right?
Since the garage is on a slab, it would be pain to run new lines of any sort up to the garage, so if I use what's already there it would be easier for me.
Any insight would be greatly appreciated!
Annette
Annette
