Resawing some butcher block
Baldewin
I was left with some butcher block after our island install that I would like to turn into some cutting boards and need some ideas. I don't have any tools to do this so I would need to acquire the tools to do this or I would need to take it some where to have it done. Wood is 2 1/4" black walnut, 20" wide by 34" long.
What suggestions do you guys have?
bergheger3
Missouri
You would need a large bandsaw to resaw it.
I would leave it that thick and just rip it to the width you want and then cut it to length. Route a dish around 1 side and round over all the corners. Finish it with vegetable oil and call it a day.
Stuart in MN
Minneapolis
To be clear, are you talking about sawing it into thinner pieces (i.e. from 2 1/4" to 1 1/8"), or do you want to cut it into pieces that are smaller than 20" x 34"? As others have said, cutting it into thinner pieces will require a very large bandsaw. For the latter, any old hand saw will do the job.
turbowoodworker
Apex NC
Do you really mean “resaw”? That term means you are cutting the 2 1/4” dimension. That is at least a twenty inch bandsaw as it sits unless you cut down one other dimension. If that is the case, a mill may have that capability.
Marctrees
TX/LA border - Toledo Bend
Large bandsaw run by someone experienced resawing w it.
NOT a first day yahoo.
Then they plane it before you leave.
They may also have a "Wide Belt Sander" also.
Could be a $20 if Country, could be $100 if City.
BTW - NOT any Veg oil.. sticky and rancid in time.
Just plain no additive Mineral oil - Any pharmacy or Walmart health dept.
Marc
The Cobbler
you probably would have better luck finding someone to rip it into 3 or 4 pcs (at a seam) and have the pcs resawn and laminated back together .
you need 1 massive saw to resaw 20" material . still becomes is it cost effective ?
Marctrees
Cobbler - VERY good idea.
Would definitely be easier to find someone to do it thaat even.. even a Cab shop that works w solid wood probably.
OP - Just keep in mind it will probably cost you more than you think..
WAY simpler to leave full thickness and have a neighbor w a decent tablesaw do it.
Marc
bullnerd
Jersey
Bandsaw mill.
Stop by that Wilkerdos chicks house, she has a fancy new saw, take 5 mins.
