Freshmeat
I have two air compressors I coupled together for my garage. It's a great set-up, as I can close off either compressor when I'm simply tinkering or run both when we're doing heavy duty wrenching.
My problem is that both compressors have leaks so they run an awful lot more than they need to. Without running any tools, both kick on roughly every five to ten minutes.
The vertical unit is a 110v unknown brand (bought it on Craigslist for $50 needing a regulator) and the leak is at the pressure switch, where the plastic section mates to the metal. It appears there's a glue of some sort that was used to seal it somewhere along the way- I don't know if it's original adhesive or if it's a previous owner's failed attempt to seal it. The leak is on the top side of the switch directly between the metal and plastic.
The horizontal unit is an old Sears-Roebuck Craftsman compressor. 220v, oiled pump. Someone left it at my parents' house probably a decade ago and never went back for it after numerous reminders it was there. I replaced the switch and changed the oil; it works great other than the leak. This one is leaking at the round air manifold between the top and bottom sections (the flathead screws hold the two together) as if there's a torn gasket.
Does anyone know the best way to reseal these two compressors? They run great. The vertical is insanely loud (I believe part of the exhaust assembly is missing), but still works too well to really want to replace it.
I have clearance to go pick up a new Ingersoll-Rand compressor (220v, 60gal, 11CFM @ 90psi) but if I can get these two running for the cost of resealing them (or a new pressure switch for the upright) I'd much rather do that so I can spend the money on something more important, like a new tool box.
These are strictly for hobby work (primarily modifying off-road vehicles) so I don't specifically need a massive unit. The pair are almost perfect for most of what we do here, but I'd really like to get them sealed for longevity and so my electric bill can catch a break when they're being used.
