joefbeams
Old House was wired in 1949 with 30 amp main fused panel which was common in rural homes. It was later upgraded to 100amp main (with fuses for the branch circuits) serving the 30 amp as a sub panel. There appears to be 2 small grounding conductors coming from those panels to a driven grounding rod. The wiring was later upgraded to a 200amp main panel (provided by the power distributor free for customer installation) mounted outside at the meter: the 200amp main panel serves directly the existing 100amp panel as a sub panel; and 2 or 3 branch circuits protected by breakers. The grounding Conductor is connected to the incoming service ground (above the meter and 200amp panel) and runs to the driven grounding rod along with the 2 grounding conductors from the exiting panels as mentioned above. The washer and dryer was relocated to a new location-- grounded together to a different driven grounding rod. The question: is the house and Washer/-Dryer properly grouned and if not --how to correct. Joe Boehms
