So I opened up my old factory singer machines motor tonight. It is a robbins and meyers from the 30s if it is orginal to the machine. Any how it is not a normal ac capacitor run motor and I cannot figure out how the wires should run. The ancient gaffers tape came apart when I pulled the housing apart. Before that it smoked a little on start up, and ran the same direct with polarities reversed (there are no clear polarities marked on the wire or elsewhere), otherwise fine.
Is anyone familiar with this motor style? It has two windings one small that switches off after starting the machine. Each winding has two ends and there are two posts with cotter pins soldiered to wires running through those. The posts go to the same side of a housing end. I understand the principals of this motor style but can't figure out how the wires are intended to be run.
The taped blue wires are untouched white and yellow I am not sure about.
Does anyone know how these should connect?
