Restoring 1943 Delta bench grinder
JohnnyNitrous
I picked up this awesome looking 77 year old grinder the other day. I'm tearing it down to clean up and put new bearings in and then paint. I would like opinions on paint color. Should I stick with the original dark gray machine color or go with black like I want?
JHuston
Canton, Ohio
Ultimately, it's your machine, but I think any color that seems period will look good, if applied well. My Delta 7" pedestal grinder is the original blue-gray Delta used on metal working machines during WW2, both because that fact is a neat piece of history, and because of the sentimental value of the grinder ( my wife found it for me at an industrial surplus house for 90.00, and was grinning ear to ear at her luck). a satin black would look "right", if you polish the hardware and do a neat job; remember, a lot of machine colors back then were kind of muddy to our modern eye, so anything that is a bit subdued will make visual sense. Just don't paint it a neon color, and you can't go far wrong.
Excellent find, by the way.
-James Huston
J
JohnnyNitrous
Also came with this Sioux grinder, a bit more heavy duty. I will restore it next.
JHuston
Canton, Ohio
I redid a sioux grinder for a friend a few years ago; I found Rustoleum appliance epoxy in stainless steel was a good match for the original finish. I agree it's a stouter machine. Be careful when disassembling; the centrifugal switch will break if you try to press the bearing through it. Unscrew the bakelite switch base as soon as you can get to the screws, the bearing doesn't fit through it.
-James Huston
J
JohnnyNitrous
-James Huston
Thanks for the heads up. That one will likely get a factory look, I like the color.
J
JohnnyNitrous
The more I think about it, the more it feels wrong to throw black on it. I think I will go with the original dark machine gray. It actually looks nice under the old nameplate.
jabberwoki
puyallup wa usa
Hopefully this will spur you on.
Stuart in MN
Minneapolis
I'm actually kind of fond of that green color in the original post. There must have been a zillion gallons of that stuff sold in the 1950s, and most of it went to high school shops where the teacher had the kids paint every machine in the place with it. :) I have a Delta wood lathe that came out of a school shop, and it's painted that exact same color.
J
JohnnyNitrous
Ya I hated it. I also didn't end up liking the original grey color so I went with semi-gloss black. I'm happy with how it turned out.
