Restoring a smal block grinder - opinions
K Powers
Alabama
Picked up a 1/4 hp split phase grinder, its still in work, but wanted opinions on the red and name plate options. I'm split on the red color not sure if I'll keep it, and the plate was FUBAR'd when I bought it - thought of replacing it with a craftsman logo or decal
Jim_No_Garage
Millington NJ
So did you do a bearing replacement? If so - how hard is it to do? I picked up pretty much the same grinder and it will need bearings shortly. I've never tried it . . .
Cheers
Jim
ganymede
New England
I like that color scheme. Good job.
If there's a flea market nearby see if you can pick up a trashed craftsman tool box or socket set box for cheap just to get the plate off it.
K
K Powers
Alabama
Jim,
yes, swapped the bearings - very easy. both stayed on shaft when removing housing. only thing is the right side housing has a inner lip so I had to remove bearing from shaft before I could remove the rotor. After cleaning new ones went on no problem
nine4gmc
Dallas
I like the red, maybe you can have the label reproduced in vinyl or wet apply decal and stick it on the plate. I think member thundermug made a decal for my drill press.
K
K Powers
Alabama
thanks guys, its settled the red stays, and I'll keep my eyes open for some type of badge that would look right.
