Restoring nuts and bolts
Copymutt
Colorado
A simple technique.
Some restorations involve keeping every nut/bolt original. Many times they are corroded and need clean up. Typically I hit my bench grinder with a wire wheel.
A good method to keep control of the nuts is to thread them onto the end of the bolt and proceed. Catch the circumference and one side, then flip and rethread.image.jpg
Ohmthis
Outside of Louisville KY
I use this method a lot at work. I keep saying I’m going to grab a steel and brass wire wheels for an extra grinder that I have. I have it under the workbench in the basement shop, out of sight, out of mind I guess.
engineer2
Chicago burbs
I've got a 5 gallon bucket full of older GM nuts and bolts. I need to find a way to clean them in bulk. I suppose they'll go into the parts washer first for a good soaking. After that I don't know.
Zrsnopro97
Wire wheel has always been my go-to for cleaning up old slightly rusted stuff.
kabinenroller
S.E. Wisconsin USA
In my restorations I try to reuse all the original hardware for authenticity reasons. Most of the time the hardware was originally black oxide sometimes it was zinc plated. I always degrease the parts first then blast them with a media like iron oxide, I do not use sand. If the hardware needs to be black I parkerize them, if they need to be plated I send them out for either clear (silver) or yellow (gold) zinc plating. It is very labor intensive to properly restore the hardware but effort shows in the finished restoration.
jbfsr
Hampstead, Md
I to try to restore original hardware. I did three WW II generators. Got tired of using the bench grinder with wire wheels. Too small of a surface area. I made this rig. I find it much safer with greater control. I'm using an old 1 hp motor.
Dutch01
Kempton Park, South Africa
I have de-rusted soaking items in vinegar, but found that you have to neutralize the acidity afterwards. Not tried it myself yet, but also heard of de-rusting items soaking them in Coca-Cola for some time :unsure:
Lwel9226
So Oregon
Try molasses..... Mix 1 part molasses with 6or7 parts water if I remember correctly....
Let parts soak for a day or two, longer if necessary.... You will be amazed at the results....
They say you can't over soak.... Just eats the rust.... not the steel....
You need to oil them after to prevent flash rust....
LynnW
