johnbennetch
I want your ideas. I am building a garage at the edge of a drop off to my back yard. It only drops about 7 feet. So I dug a pit at the back of the garage. Now all I have to do is the floor and the walls so I can concrete the garage floor. This will allow for you to pull all the way in and over the pit. My idea is to make a steal cover on rollers that goes out under the wall. And use garage door springs to close it. If I put a socket in the cover to place a bar with padding on to push your bumper against then you never have an open pit to fall in. If I use a large mirror on the wall you would simply center the car un the bar that you place in the cover when you want to open it. The cover will roll along the top of the pit wall on the outside of the building. The other nice feature is that it faces the west and will give sunlight under the car. My thoughts were to use a set of glass French doors to close the pit.
