Retrofit digital doorbell to mechanical?
czgunner
WY
I just moved into our new-to-us home in WY. Hooked up my simplisafe doorbell and it rings constantly. Turns out I have a digital doorbell and I need a mechanical type. What is involved in this conversion?
vwpieces
Hills, PA
Old type door bells used a transformer. I forget the voltage on mine but I do believe its same as the 24V transformer on my thermostat. But I guess you would also need to change the actual Bell also.
Hope you do not have one of those wireless ones....
And (y)(y) CZ fanboy too.
kelpaso1
MEMBER EMERITUS
New Brunswick
Why not? That's what I have. Works fine.
nadogail
Coronado, CA
As I recall Mechanical Door Bells mounted on the door and you turned the handle to ring them.
They were replaced by Electric Door Bells which were either Battery operated or powered through a transformer; although I encountered line voltage (125 Volt 50 Hertz) door bells when I lived in Spain.
If I were to consider replacing a digital door bell with a mechanical door bell; I would first look in an Antique Shop or maybe Restoration Hardware.
rjn2649
Il, A little west of Chicago
The first question I'll ask is, did your doorbell work BEFORE you installed the new one?
I looked at their website, I sort of have issue with the fact they don't mention a voltage. AC door bell transformers like a tri voltage I think can be 8 to 24 volts.
Also if your replacing an old intercom system it could be a dc voltage.
C
czgunner
WY
Yeah, not mechanical, electrical. The tech person said mechanical.
Neggy
lots of those wireless doorbells (ring, etc) go into the old bell unit and bypass it, connecting wires so it feeds 17 to 24 volts to the doorbell to power it full time..... then it needs a wireless bell to work
If it is a retrofit unit, go up into the old bell housing and check the wiring, then put a regular momentary NO doorbell switch in place of the "wireless" one
Walkers
Cave Creek Az
To go to true mechanical just drill a hole through the wall for a rod with a return spring, then hang the bell of your choice inside at the level of the rod.
nmk_61802
Central IL
Or buy something like this and replace your current chime:
Basically need a single note bell type chime (note: says "mechanical" on HD site). I assume yours is a 2 or more note chime.
PoorUB
Fargo, ND
I tired to put in a digital wired doorbell a while back. I liked the idea because it was preprogramed with several different tones. After spending two Saturdays working on it it went in the trash and a good old two fashioned tone bing-bong went back it! And I used to do building automation, wires, computers, valves, motors VFD's. Got my **** kick by a darned door bell!
Milton Shaw
Most of those old style have only three components , Bell/chime, transformer and switch and use a simple series circuit that the switch completes the circuit and rings the bell. The nest system is a wi-fi system that uses the current from the transformer to power it.
