Reusing Oak flooring
ArtisanFarms
Phelps, NY
Has anyone reused 3/4" thick strip oak flooring? I might be able to get some from a building materials recycler for the house I am rehabbing am wondering whether it would make more sense to run it through a sander to strip the finish before laying it and than doing a light sanding once it is down, or just laying it with the finish on and sanding it after the floor is down.
rsanter
visalia ca
You need to be selective as some will be usable and others will be ****.
Typically you lay it down then sand and finish
duneslider
Riverton, Utah
There is a big market for reusing wood flooring. If the nails and staples are already pulled then its great. You can run into a lot of tongues and grooves that are broken which may just require a little more care and glue during install. If the price is good for the most likely extra effort it will require then it can be a good deal.
txvwnut
Bedford, Texas
If it’s still useable put it down then sand it. When installing traditional wood flooring it needs to be sanded with a drum sander to get all the joints level then followed up with a pad type sander for a smooth finish.
alexb2000
Fort Worth, TX
It is possible, yes. Would I do it, NO! 3/4 Oak is a commodity floor you can get at any supplier. Recycling might make sense if you have a rare wide plank antique floor with a lot of character.
38 Dodge Coupe
Delaware Ohio
As others have shared it can be done. Depends on condition of the old flooring and number of nails ( or likely staples) in it. In my experience the nails/staples were not easily removed without damage to the board. Just for perspective, when I did it on an house that was built in 1901 I had more time than money, so it's always a trade off.
nadogail
Coronado, CA
I was able to acquire a large box of new oak flooring scraps from racket ball court installation, it cost me a couple of 6 packs. I turned them into oven sticks and knife handles
