I've used mostly V/A & Norseman HSS bits and a couple individuals (Irwin, Cleveland, Snap-on, ete.), all worked within reason for what I was doing, Length was the only issue that would pop up at times.
I'd buy from someone who actually manufactures twist drills. Norseman are very good. Made in the US.
Snap-On or Matco or MAC don't actually make bits. You get whatever rebrand they're selling this month which may or may not be the same as the brand they sold last month.
Pretty sure all the trucks rebadge the ones Irwin makes. They hardly ever work unless it's something clean and/or new. Corrosion and rust? Just about worthless.
You want stubby cobalt left-hand bits IMO, perfect for angle drills and manifold studs. Snap on costs basically what all the other popular USA brands do. I've found as a general rule, USA made drill bits are all good.
Spot weld bits are also good to pick up as singles, for cleaning an area prior to welding a nut on the fastener. They're only available in right hand thread, but they really do rip through the ********.
I’m certain you’re correct about the first point, but strongly disagree on the second. Obviously we need multiple solutions for removing broken off fasteners, because every situation is slightly different, but reverse drill bits have been one of the tools that make me look like a rockstar over an over again.
It could be that I’m dealing with completely different fasteners than you’ve experienced.
I have always used the SnapOn, but just because of the convenience, not brand preference.
It's amusing techs think the only thing that exists are tool truck brands.
Order your choice from an actual machinists' supply house like MSC. Trust me, Snap-On does not have some magic for cutting tools.
NOW, if your truck guy will warranty broken ones and you feel you can get the ROI that way, that's a different story!
And LH bits are the bomb-diggity for broken removal, they work wonderfully if you know what you're doing and use proper technique. Although it doesn't hurt to have a few lathes sitting around because oftentimes I'll make a custom bushing or guide to get started centered on the offending fastener.....
