Review - Mityvac Radiator/Cooling System Test Kit ($46)
HoosierBuddy
Southern Indiana
Hey guys,
I forked over the $46 to order this on Amazon the other day and was really impressed with how helpful it was. Not sure how many of you non-professionals have one of these in your toolbox, but it's at least worth considering if you are trying to track down a very small coolant leak on one of your cars or trucks.
Essentially, it's just a little hand pump and 4 adapters that let you take off your radiator cap and pump 10 PSI, or so, of air into your cooling system to simulate the pressure it will see when it's HOT...without getting it hot. Then you can track down your leak issue pretty quickly.
In my case, I was attempting to locate a very small leak on a Subaru WRX that was so small it really didn't even create drops on the ground. The coolant was evaporating from the leaking area without dripping. Unfortunately even that small of a leak would allow enough coolant out of the car to create air pockets after a month or so if sitting, that would cause the car to puke out the rest of the coolant once you tried to drive it.
I hooked up this mityvac unit to the coolant tank near the intercooler and it took 60 seconds to verify the leak was coming from the radiator area. It was a bit more work to remove the radiator from the car, disassemble the electric fans from it, plug all the holes and retest it separately to actually SEE where the leak was...but once I did all that and used the mityvac directly on the radiator (filled with water) a small leak was clearly visible on the engine side of the radiator right above the transmission cooler tank.
I've chased a lot of small coolant leaks over the years that I think this pump would have really been a huge help in tracking down. Glad I have it in my toolbox now!
Phil
dbabicky
NE Wisconsin
We have similar kit sold by ATD, more than likely made by the same company, love it . Well worth the price !!
George in Rancho Cordova
Be sure to release the pressure slowly when connected to a filler neck.
I didn't and coolant ended up inside the pump.
By the time I got around to disassembling and cleaning it, the pump was inoperative.
A rebuild kit is about $12 plus shipping online.
GirchyGirchy
Central Indiana
I have one of those...have used it several times, it's super handy.
Only time I had trouble was when the plastic top cap of my wife's Galant had a 3" long crack in it. Air was leaking out just as fast as I could put it in via the hand pump. Was able to spot after saturating several areas with soapy water though.
H
HoosierBuddy
Southern Indiana
I had a similar issue when I was attempting to test the radiator by itself with some pvc plumbing caps stuck in ends of the disconnected hoses to cap them. First time I was leaking enough through one of my jury-rigged caps that I couldn't build pressure. I found it by sound. I could hear it hissing and got it re-rigged well enough to do the test.
Phil
BillK
Beautiful Southern Maryland
I have an older Mityvac kit and would like to make a suggestion since this thread is here. I have had it probably 10 years but it has only been used a few times. I went to use it this weekend to bleed the brakes on my Wifes car and it would not hold a vacuum. I took it apart and found that the surface that the check valve seats on has corroded :( The check valve is basically a Holley carburetor accelerator pump check valve and it needs a pretty smooth surface to seal on. The sealing surface is down in the bottom of the pump cylinder and is going to be very hard to repair.
I am bringing this up with the suggestion that maybe if I had put a small amount of some type of light oil in it after each use, it may have prevented the problem. Might be a good idea.
Hope this helps,
