SarcasticDwarf
Finally bought a house with a fantastic garage but the wiring leaves a lot to be desired.
Current configuration: 200amp main panel in house, 100amp subpanel in garage. All cables for the basement run through a full wall cavity. While the previous owner managed to get a cable from the main panel through the cavity to the garage, he could not fit another one for the a/c. As a result this pulls off the garage panel.
What would be the best way to fix this? Run a second large cable to the basement for its own subpanel (the other large cable is the one going from house to garage through basement)? This would allow me to eliminate all the other wires in the wall cavity but result in two subpanels.
The only other option I can think of is to run conduit between the attic and basement, but it seems like there are quite a few issues with this (cable fill, length limits, etc.)
The intent of this is to get the a/c off the garage panel and to fix the wiring that ranges from old (1950's) to sketchy.
i say that when Im pulling all the hack work out of customers panels...
