Ramper
We picked up a popcorn machine for FREE off of CL. The kettle wiring was all burned out. I ordered High Temp wire and attempted to rewire it. I plug it in and it immediately blows the GFCI as soon as I flip the switch. The wire size is OK (12 gauge and only 9.4 amps)
I have attached a wiring diagram. It uses a twist plug. I connected the wire that is grounded to the kettle frame to the green screw. The wire to the thermostat to the silver screw and the wire directly to the heating element to the gold screw. I assume (in my limited electric knowledge) that the gold and silver connections could be reversed.
The light and motor work fine so there is power running to the unit. The kettle is all that is not working.
THANKS FOR ANY SUGGESTIONS. I have already spent $30 in wire for a free machine.
