trackwelder
Looking to upgrade the wiring to our above ground swimming pool. Currently it just a 20 amp circuit no gfi. Just curious as to any recommendation on what should be done.
OK I give up! How do you bond to the "Pool Deck" when it's either Cedar, or a composite??
AL
Hmm - we ran an above ground for years and never had anything more than a GFCI on the 1HP sand filter. The motor was grounded through the plug, but the rest is all plastic. Not sure why you'd bond the frame or anything else. I don't think pool water is that conductive, really. Maybe if you run one full of salt like some are doing.
AL
has to do with nec 2008, i just finished wiring mine.
