Hi guys,
I am reading it is now best (or maybe even code? Ontario, who knows) to have a neutral wire in the switch box for all switches.
So maybe I am misunderstanding, and I have no problems wiring this way (in fact I am more comfortable doing it this way since it's the way I've always done it), but from what I'm thinking, that means that the power must always run to the switch box first, and THEN the lights. Am I misunderstanding?
So as a 'for instance', in my case, the breaker box is on one side of the garage, and the switches on the other side. I will be running 2 switches, for 2 rows of fluorescent lights. This may be the first case where I've had lights in the middle of the run, making me slightly confused.
I know you can wire into the fixture first, and then the switch, but if you want a neutral in the switch box (for smart lights, etc?) then from what I'm gathering, you have to run from the breaker box, all the way to the switches, and then to the lights (And tee off for whatever outlets).
So if my thinking/understanding is correct, I would have 2x 14/2 wires going to the switch box, for each row of lights, which can't even be done in a normal switch box I don't think (Since you can only have 1 wire per hole in the switch box, and I would need 2 wires coming down for each switch. one for power in, then one out to the lights).
Please fill me in on what I am missing in my understanding of a neutral in the switch box.
Thanks guys!
Thanks guys!
... the outlet wouldnt work without a neutral so this is inconsequential...
