1967Chevelle
I have purchased a Reznor UDAS separate combustion unit heater along with there " Aesthetic Concentric vent kit" part # CC14
I need to install Category III vent pipe, all the stainless steel vent pipes manufactures use a O-ring and gear clamp to hold the joins together,
how would I attach the Termination hood that is supplied in the reznor vent kit to the stainless steel pipe, there is no room for the gear clamp?? with the outer section being the intake area
Here is Reznors instructions but they state to fasten the termination hood with screws as you can see in there pictures they are using Snap lock Galvanized (category I) vent pipe, you can see the joint line on the vent pipe in there pictures
http://www.reznorhvac.com/files/I-UDAS-UDBS-ASC (.4) PN209344R4 for screen.pdf
