blenderbender
- Joined
- Jan 5, 2022
- Messages
- 12
I hung a Reznor FE-200 (200,000 btu) unit heater in an ag building recently. It's supplied by NG and supposedly worked when uninstalled previously before I got it. It sat around for a couple years before I got around to hanging it. Fan motor was slightly stuck, but easily returned to function properly. When I first tried to light it, the ignition spark is steady and clean, but pilot would not ignite. I then dropped the ignition/pilot assembly out from the bottom and then it lit no problem. But when I reinstall the pilot will not light. I manually lit pilot with a small butane torch and then everything happens as it should..... burners light, blower comes on when it gets up to heat. When the thermostat is satisfied and everything shuts down though, the pilot will not re-light when thermostat calls for heat again. The only tiny (in my mind) out of the ordinary thing that I've noticed is that when I manually light the pilot with torch, there is a slight gas leak at the fitting on the pilot line to the pilot as it ignites also. I tried to tighten it but it was to no avail, the gas is still leaking slightly at that fitting. The pilot, when lit, appears strong, and to my eyes, substantial enough. But for whatever reason it does not want to light on it's own when up in the burner box...... thanks in advance for any ideas!
