vavet
I should clarify...I *think* this is RG59 cable...but my google-fu tells me the copper core should be about 0.8mm and mine is 0.4mm.
I have a Q-see DVR with the Siamese coax/DC power cables. I'd like to shorten the cables to get rid of the excess wire that runs into the cabinet.
I ordered a cheap crimper, stripper, and BNC cable ends from amazon. I figured I'm only doing 3 of these so I can cope with cheap tools. Hopefully that's not my downfall.
So here's where I am: I've stripped the cable. I have the copper braid peeled back. I have the dielectric, and I have a portion of the bare copper conductor in the middle.
The BNC conductor appears to have two pieces of metal folded together that prevents insertion of the conductor. The conductor bends if I try to force it. I sacrificed a connector and forced a small screwdriver down between the two folds...now it's wide open but won't clamp the conductor.
I've watched several YouTube videos on this process. Several of them are using connectors with separate pins that get crimped onto the conductor. The connectors I have already have the center pin inside the connector. The other videos I've seen just show the person inserting the stripped/prepared cable into the connector and crimping it. They don't seem to have the issue I'm having.
At first, I thought the connectors I got were defective. I've ordered new connectors and they are the same way. What am I missing? How do I insert the center core into the connector?
