Ridgid and Southwire Extension Cords
rusty_ratchet
I am looking for a good 50' 12/3 extension cord. I've seen a lot of good reviews for Ridgid and Southwire cords. Does anyone have options or experiences that one is better than the other? Is there another good brand of extension cord?
Also, Home Depot has the Ridgid cord for $63.97 and Amazon has what appears to be the same cord for $35. Are counterfeit cords an issue, or is this just a good deal?
R
rusty_ratchet
redwrench60
East Tennessee
I have a couple of both. I’ve had the Ridgids for years (50’ and 100’) but bought two 50’ Southwires on clearance. The Ridgid is a much better cord. It stays flexible in the cold and takes twists, kinks and abuse better than the hard vinyl Southwire cords.
On an unrelated note a very good friend of mine is in charge of a large facility and orders the Ridgids for his housekeeping staff and says they last the longest of any he’s tried. Also if there’s an issue with one that’s not simple wear and tear he takes them back to HD for a replacement under Ridgids lifetime warranty.
theoldwizard1
SE MI
I haven’t had any problems with them over the past 5 years. I’m not real picky about extension cords though.
https://www.costco.com/outdoor-50-ft.-extension-cord%2C-2-pack.product.100336733.html
The reason these are so inexpensive is the type of insulation that was used. SJTW. It is thermoplastic. Better cords are SJOOW, use a synthetic rubber insulation that make them more flexible, especially in colder weather. Both of these cords are "weather resistant" but the more expensive one insulation is "oil resistant" on the inner and outer layers.
American Locomotive
Rhode Island
If you live in an area that gets cold, I'd really avoid PVC or SJTW jacketed cords. They get super stiff once the temperature drops.
Look for SJOOW, SOOW, or SJEOW cord as mentioned. They will remain flexible even in extreme cold. I find that these cords also tend to hold up better than SJTW cords.
timdgsr
Birmingham, AL
Gotcha! Thanks for the info.
Handyandy23
Ontario, Canada
Where does SJTOW fall? Is it more similar to SJTW or will it stay flexible in the cold?
tarbellb
Oregon
This^^^
If flexibility is important to you and/or cord memory ie. becomes permanently twisted
then avoid any cord composite that has "T" in the makeup. T = thermoplastic, which means it becomes stiff in cold weather and also is prone to warping over time.
M6erfan
'Merica!
Good info about the insulation, something I didn't know.
It's important to know the differences when assessing one's needs, and when price shopping to make sure you're comparing apples to apples. Another factor to consider is the cord ends/plugs.
A lot of extension cord reels use the 'T' type cords, even high end expensive models :dunno:
The US Wire & Cable cords linked above are very nice.
nh_yota
Seacoast New Hampshire
I prefer Ridgid for my "good" cords because they are more flexible and are overall a better cord. If it were up to me all of my cords would be the "better" ones but sometimes all you need is something that's good enough for the task at hand.
larry4406
Northern Virginia
Agreed the Rigid cords are flexible which is nice.
vavet
Ashland, VA
I have a 12/3 25’ Ridgid that is awesome for using inside my garage. I’ve had it over 10 years with no issues.
mike93lx
Richmond, VA
I have three us wire and cable 12/3 cords. They are very high quality and have been holding up very well for a while
matt_i
SE Michigan
My favorite cords are ones made with Carol SJO cord.
Of course these are not molded plugs, but source some Hubbell 5269C and 5266C ends and you are in business.
Then you can make up any length and/or choose a different gauge of wire as needed.
R
rusty_ratchet
Thank you all so much for your replies. It has been very informative and helpful. I am going to go with the Ridgid cords for now. If I need something better in the future I will pursue making my own cable with one of the heavy duty cable types mentioned.
