Ridgid power tools
bobg03
conway sc
What is the general consensous on Ridgid power tools? Being retired now I was thinking about a bench and some basic woodworking tools so that I could dabble with learning how to do small projects.
I can assure you I will never have to do any remodeling jobs with them...lol
IMStuner
I have a bunch of Ridgid tools and they have held up over the years. The LSA is great if you follow the rules and register the item.
59 wagon man
hollywood fla
lsa is soso .i have one of their mini sawzalls and i have registered they agree but the seriel number is under someone elses account but i bought the tool new and it is in my physical possession. and always has been and they won't replace it so i went to milwaukee m12
jd_1138
NE Ohio
I think they will be fine for homeowner use. And I bet there are carpenters/contractors who use them for remodeling even for customers. lol.
I am in Makita and Ryobi, and I've built small decks and stairs with the Ryobi 1/4 impact driver and the regular drill, though usually, I bring the Makita stuff. I am not a pro -- just do some projects for relatives/friends sometimes.
vavet
Ashland, VA
I am the caretaker of a bunch of Ridgid tools. I have my own set for home use. I am also the custodian of 3 more drill/impact driver sets, plus recip saw, circular, light, and cordless vac in my workplace.
Performance-wise, they are fine. Don't buy just for the LSA. They make it difficult. There are rules that don't always make sense, but if you follow them, you will generally be OK. I say generally because I've had two experiences that give me pause.
1. I took my recip saw to HD rental counter to be shipped out for LSA service because it stopped working. The guy at the counter gave me a brand new recip saw off the shelf and told me it would be fine. I called the next day to register it (it wouldn't let me do it online because it was a replacement) and was told there was no way, no how, I could register that new tool for LSA because I didn't purchase it. I either needed to get my old tool back or I needed a receipt, even for $0.01 for the new tool. I called HD immediately to try to get it sorted out with no success. I stopped by on my way home and we got it sorted out, but had I not been proactive, I'd have been out of my LSA on that tool.
2. The cordless vac is super handy, although it ***** down batteries pretty fast. I took that in to the HD rental counter (different HD). They shipped it off. They called me a couple weeks later saying it was back. I went to retrieve it. They finally found it and decided it wasn't repaired. The reason is because the place they shipped it to doesn't repair those. Those vacs are just replaced by Ridgid after you email pictures of the vac from certain angles. I guess they try to determine if it was somehow abused based on the pic. When you ship off a tool through HD, they charge you ~$20, to cover their costs in case it's not covered under LSA. You get it refunded when you pick up the tool...in this case, they didn't want to refund it because it wasn't repaired under LSA. I'm not the expert on what tools should be shipped back. I did finally get it refunded, but it's not a pleasant experience.
I've since found a local lawn mower repair shop who is an authorized Ridgid LSA service center. I took an impact driver to him. He replaced the motor and called me the next day to retrieve it. That was lucky because he happened to have a motor on the shelf. I know it won't always be that fast, but still...that's awesome.
If I was starting fresh, I would look at Ryobi. They have a much wider variety of power tools and outdoor tools available.
jgromada
Maryland (between DC & Balt)
i haven't had to deal with the LSA yet thankfully. My stuff has worked out well and i think in general Ridgid is priced a bit better than DeWalt or Milwaukee. I might prefer DeWalt but Ridgid is more budget friendly.
Citation
Indy
I have a few of their tools, a Gen4 brushed 18V drill and impact driver set, a largish shop vac and I fixed then gave away one of their pancake compressors.
The drill and impact driver seem like very competent tools in a sea of very competent alternatives. I shopped based on price at the time. The only issue I have is the impact driver is not speed adjustable like many others (adjustable via a switch, not just trigger control). No complaints about the drill.
The shop vac hasn't been used much and has worked great every time I've used it.
The compressor has somehow over heated the motor to the point that the glue stuff on the motor windings had melted which resulted in a seized motor. With a lot of disassembly I got this fixed and the compressor seems to work fine now. Note that the compressor was bought broken as a project/challenge and I have no idea how it was damaged. My brother still has it though I suspect it gets very limited use.
Overall, as a home owner I wouldn't hesitate to get more Rigid tools but I don't see them as special compared to the competition.
toyotadriver
I bought a Ridgid impact driver and then a Ridgid drill. They have been fine. I had to replace the battery on my first tool. What a headache that was. Now THAT battery is bad and I haven’t bothered to replace it because it’s a pain.
I’m switching to M12 and M18 tools.
Badgerstate
Columbus, OH
IMO, for homeowner use, Ridgid is fine. Its under the TTI umbrella, along with Ryobi and Milwaukee; so its from good stock.
Fly YX
The battery is super easy now just call this number and they will send you a new one just remember to call when you get the new one and give them the serial number of the new battery.
duneslider
Riverton, Utah
I have several ridgid tools and like them a lot (router, table saw, 1/2 mixing drills, roofing nailer). I have had better luck with them than milwaukee and dewalt. The only issue I have had with my ridgid stuff was the switch went out on one of my mixing drills after several years of daily use. I don't bother with the LSA, the switch cost me a couple bucks ordered online.
fourjeepin
Atlanta, GA
I have a bunch of 18v stuff and a few corded. I have been abusing the batteries for years and haven’t had one go bad yet. Only time I needed to warranty a tool was my abrasive chop saw. The repair place gave me a brand new one.
Canton, MI
I have four Ridgid tools: 2 vacuums, oscillating sander (love it), and 1/2" corded hammer drill. They all function fine, and I've had zero problems with any of them. The hammer drill is a beast.
bubinga
If I buy a Ridgid tool and have it shipped to someone else for their birthday can they still register it?
dylanmitchell
Southern California
What are the best 7 to 10 foot 1 7/8 hoses for Rigid vacuums? The 1 7/8 10 ft pro hose isn't a ton better than the standard hose and uses a lot of fitting. The 1 1/4 pro hose from the cart kit is easier to hook up, but larger objects get stuck in the hose, and Cen Tec only has a 1 1/2 5-inch hose. Rigid is trying to make all their hoses work with all vacs and attachments, but I'd rather have a not extra attachment needed hose. 1 1/4, 1 7/8, 2.5 hoses plus a bunch of pieces to try to make them work on all vacs and attachments vs just giving us a good old 1 1/2 inch hose and a 1 1/4 inch step down that would be so much easier.
