Cargo
Welcome to my current little rescue project. A Ridgid model WD16350 16 Gallon 6 Hp wet/dry vac.
This vacuum was abused by the previous owner. They ran it with no float or filter and kept it outside. They also, apparently, thought that cleaning out whatever vile funk it was used to clean up didn't need to be done either. Luckily, that has dried out for long enough to come out in chunks -for the most part.
Please don't ask why I am trying to rehab this item. That would just bring up issues about my sanity that are beyond the scope of this thread. The upshot is that I am trying to take the motor out of it for some much needed TLC (and to avoid getting it soaked in re-hydrated funk during the cleaning process).
Everything is apart and all screws are out. I have it down to the spacer under the impeller. Does anyone know if this is a press fit item? Light hammer taps on the shaft and a day and a half of kroil have not budged it. Can't pry against the plastic housing with any real force. It could just be corroded in place but I don't know and have not been able to google up anything more useful than a parts diagram. If you have had yours apart or have a service procedure manual, I would be grateful for a tip on how to proceed. Ridgid is closed by the time I am off and can call. They would probably say that "The motor is not replaceable but we will be happy to sell you a new powerhead for a bazillion dollars more than just buying a whole new vac. -because yours is special. It was only made during the last half of 2006 when all the workers got chairs with fluffy cushions and left handed screwdrivers." (Yes, I know. I'm an optimist.)
After you and your significant other finish laughing about the doofus on the 'net who can't even take apart a vacuum cleaner, please feel free to make a suggestion.
Thanks
Thanks
