right angle drill attachment
pitterpat
Indianapolis
Any of you guys have a right angle drill attachment, the one that turns a regular drill into a right angle drill? I need to drill at least 50 joists total to run electrical and plumbing on a couple of different project. I have been looking at a Milwaukee Super Hawg or the regular Milwaukee right angle drill and I can't really see shelling out 100-250 for a drill that I will have limited use for.
Yes, I could go rent it but I want to able to work the projects at my pace vs a rental pace.
What has been your experience with that drill attachment?
P
pitterpat
Indianapolis
I think if you got a nice sharp bit you would be ok...If you burn it out, just bring it back and get another one...I don't think you will impressed by the quality though...
Maybe I'll just get the attachment and use my hammer drill.
cinco
Northern CO
I'll echo the previous comments: The HF attachment is not great but it works. I grabbed mine because I needed to drill a single hole in the firewall of a Volvo I was converting from auto to manual trans so I can't tell you how long it'll last. Just stay alert if you're using a grabby bit - things move in mysterious ways when the bit catches.
Ign
Butte Peak ND
I have the HF attachment from years ago, it's got a reddish body. It's ok but not sure I'd want to use it for 50 holes.
The HF right angle drill is ok for the price, but doesn't have a ton of torque - it is a 3/8" drill after all. I agree the quality is less than stellar and the gearbox more sounds like a box of rocks or a dead cat.
Ign
Butte Peak ND
Ign
Butte Peak ND
Is air an option? I know it's a longshot as it sounds like you're on jobsites but right angle air drills can be real inexpensive and very few options are more compact.
P
pitterpat
Indianapolis
P
pitterpat
Indianapolis
Air can be an options but it can't if I need a lot of air, I have a small Porter Cable pancake compressor. This is work on my own house. I don't think I have enough air hose (maybe) to run from my workshop to the basement of my house. I am about 80 ft from the garage where the big compressor is located, then down the basement, then to the work area.....about 125 ft.
P
pitterpat
Indianapolis
Probably not enough power but the right angle thing will work but you can get a battery drill in between 16's with a short bit.
Yeah, the battery one that I think would have enough torque the batteries are either dead or bad or the charger is bad.:( It is an older Bosch.
jvitez
Big Sky Country, Canada
I bought this one, on sale now for $50 CDN, I think I paid about the same last year:
http://www.princessauto.com/pal/en/3-8-In-Drills/3-8-in-Variable-Speed-Angle-Drill/8356008.p
I'm sure it's cloned under many names as it's a Chinese special, but I used it for about 15 holes in 2x6 studs spinning a 7/8" spade bit and it worked fine. I wouldn't blow your budget on a high dollar right angle drill unless you see a need for it in the future, or you just want to have it. Nothing wrong with that...though :) But for occasional use I'm sure this type of drill will last long enough.
P
pitterpat
Indianapolis
Oops, our posts crossed. I just saw you need a 1/2" chuck. With that need you might be stuck needing an expensive drill.
Yeah I'm thinking so.....looking on ebay & CL. I do have my former neighbor who has a company that sells to the cabinet trade and construction industry, I'll call him to see if he has a right angle with a 1/2" chuck. He usually does have what I need.......one of those guys that has about 7 drills and all the other stuff.
SlappyWhite
Upper Canada
Prior to buying my right angle drill I just used long bits and drilled on an angle. Works fine for electrical wire holes. Bits were long enough to put the drill beyond the next joist/stud. It is a good option.
I bought the right angle drill not because I had to, instead...because I could (used Milwaukee for the right price).
Edit, how old is the house? If it is built with what I would consider old growth timbers they can be really hard to drill, they are alse very dry. Modern stuff is really easy. My point is, how much torque are you going to need? My 1/2 makita will stall on old timbers, my PA gear reduction and right angle Milwaukee will just power through. How will the right angle adapter hold up may depend on the wood....
rslaback
Westcentral Wisconsin
This looks ok but I need 1/2" chuck to use self feed bits; I have over 50 yr old joists.....real wood.
Honestly, I prefer a good spade bit to a self feeding auger when popping holes in joists. Especially old growth timber. In my opinion until you get a hole depth in the 3 inch range a spade cleans better.
P
pitterpat
Indianapolis
I've got the spades, I may try the right angle attachment on my hammer drill....I know I have a right angle attachment somewhere but I don't know where...time to buy a new one.
sberry
Brethren, Michigan
Invest in a good battery drill now when you need it, the rest is a one time shot and big cost for a diy, when you finish a few minutes work you will be left with a drill you need and have a use for.
danski0224
Near Naperville, IL
Milwaukee has a D handle 90 degree drill.
You may be able to source this part: http://www.milwaukeetool.com/accessories/miscellaneous/48-06-2871
And this part: http://www.milwaukeetool.com/power-tools/corded/1007-1
Separately to "build" your own for less than buying the complete 90* D handle drill as a kit.
That drill and sharp bits will do the job. The Lenox "One Tooth" are supposed to be good.
A Hole Hawg will tear your arm out if you don't pay attention.
P
pitterpat
Indianapolis
Ok, lets get back to this one. I ended up not using the right angle attachment, I did find it but it was dope, just wouldn't work right and it kept swiveling around. Just a real big PITA. So then I got my old trusty Craftsman 3/8" old drill out, had it since like '86 or so. It would fit between the joists and had enough torque to go through that old wood. I drilled 3/4" holes in every joist I needed, about 12 (first round of holes) I used a combination of a stubby spade bit and a stubby auger bit (kind of lame).
I had to drill 1 1/2" holes in 2 joists that made up the cold air return to run the conduit through. Drilling the 1 1/2" holes was another story. The first one went pretty good, just used the 1 1 /2" spade, it took a while but got it done. The 2nd one was a bear, the angle I was at was bad, drill was heavy, everything was just awkward. It took me a entire week to get one hole drilled. All of the holes were overhead but this one was just horrid. I used a spade bit, a smaller forstner bit and a 1 1/2" hole saw.
The reason those holes are 1 1/2" is because I had to seal up the holes; I used a piece of 1" schd 40 pvc to put through the 1 1/2" hole and a 6" tail piece on each side to seal the hole. I'll go out later to the cold garage and get the caulk to make sure it has a real good seal.
Here's pics of the cold air return w/the PVC run through it. The 1st pic is the pvc and tailpipe outside of the air return. The next 2 are what it looked like once I ran it through and glued it up. No caulk yet. Also, the reason it is back in like a hole is because my kitchen cantilevers out over the house foundation like 2 ft. When I get this electrical done next is time to start on drilling holes for the new pex install; that will be up through the joists just above where the galvanized plumbing is now about 6" out from where the electrical is run.
Kev442
Wi
Perhaps a forstner bit would be short enough to use your regular drill? That works for me on 16" spacing.
ez-duzit
Marina del Rey
That's what I've been thinking as I've read the thread. My 1/2" Milwaukee is short enough and has the power to make easy work of it with a forstner.
OP--If you decide to buy a tool, buy a good one, even a used one--not some throw-away.
mrtoolfool
Iowa
I have cut down both spade bits and self feed bits to get into tight places.
Cut the shanks off at whatever length you need all the way up to where there is just enough shank left to chuck it up.
They are cheap enough and i have used the cut ones on multiple jobs.
Sometimes if drilling thru more than one thickness of 2x you can use the short bit to start then put the longer bit into the hole before putting it into the check.
P
pitterpat
Indianapolis
I always buy quality tools, even though the Craftsman name has lost a lot of luster today, 25 years ago it was good stuff. I have had that drill for at least 25 years, that's why it had the torque to do those 1 1/2" holes. They were just at bad awkward positions. Most of my tools are Bosch, Fein and Milwaukee.
454ragtop
Carver, MA
Probably too late, but I have an extra Sioux close quarter drill I could sell you pretty reasonable.
Jim
P
pitterpat
Indianapolis
Jim
Thanks for the offer but I'm not sure about the power/torgue. I rented a Makita (just like the Milwaukee) right angle drill for about $18. Powered through the hard, concrete like wood I have. I have 1" to 2 1/2" holes to drill, the ones I have drilled now will get me through until after I come back from FL for Xmas.
Thanks.
