right angle ratcheting bit holder?
n8n
Curtis Bay, MD
Sometimes you need one... I had a cheap Craftsman one and can't find it now. Had occasion to use it the other day - I had to replace a hood release cable on a Jeep XJ and needed it to remove the plastic trim without removing the driver's seat. Ended up using a 1/4" combo wrench on a screwdriver bit, not optimal.
I've already bought the Snap-On stubby ratcheting bit holder and have resigned myself to the fact that I need the full size one to be happy. Does SO make a right angle bit holder as well or if not who makes a nice one? The Craftsman one worked, but the sloppy coarse tooth ratchet didn't make me happy deep down inside.
BFHtime
I have a dewalt that I use with my impact driver. Milwaukee has a heavy and light dirty piece, both of which I would like to try, but I plan on getting the heavy duty one for sure, not 90 degrees though.
The dewalt was cheap, it was an impulse buy, and has worked great and held up pretty well despite it's scrapes and bruises, about 100lbs of torque max into it. About $15 maybe.
Different length bits are nice with the snapon ratcheting screwdriver with the square drive. Some adapters and some bits and can get a a lot done, with a few pieces. I have the stubby ratchet screwdriver kit (the first thing I bought from from my last Snap-On guy) and not too long ago picked up an adapter set to work with it. I usually grab the stubby kit for around the house stuff or for a small kit to bring into an interior or other place away from most of my tools, there is a hex to square adapter and some mm sockets. This has been very handy for me.
I also picked up ,some longer length shafts for those out of reach places, these have been great as well, plus they work with bigger ratcheting handles.
Super Sport
West Michigan
Husky sells one very similar to the Gearwrench, but it'seems a little bit smaller. It's the only Husky tool I own, but I really like it!
tbaggz
http://buy1.snapon.com/catalog/item.asp?item_ID=643972&group_ID=680939
Blue point
Hammer1963
Kentucky
VIM has a great fine tooth angled bit driver and the long flex head offered by several vendors (Cornwell is one) works great for certain applications
Air21
This One is the one I've had my eye on for a while, its on ebay right now for about $20. I like the hex socket in the end that you can turn with an allen key in tight places.
rob0781
Canada
I've got this one. Works good for tight spots like under dash interior work.
gungatim
west mich
I've been thinking of getting one of the gear wrench sets. #30035
looks identical to the Kobalt set I picked up on clearance for $10, except the case is blue instead of red. works really well and surprisingly high quality...
N
n8n
Curtis Bay, MD
Oh... that snap on is nice. Does anyone find the extra size of the ratchet head to be an impediment to use compared to the flat types (like the Blue Points posted farther up?)
ss454
mi
ive got the older blue points with the red handles similar to the blue ones above. ive also got a baby chrome snap on ratchet with 1/4 female hex for drive that is really nice.
warweapon762
I've got the Husky model and one of the Harbor Freight ones which I think is based off an old Soviet armorers bit wrench design.
I think I've used the Husky one twice so far for adjusting idle mixture on carbs. The HF one sits around as back up, but I have used it to gain access to a hall effect sensor on a distributor.
Both are fairly inexpensive.
HF model:
I hear these are all the rage for disassembling dash assemblies too.
sam.coll
Melbourne, Australia
Lately ive been looking really hard at the Kastar line of bit ratchets, think im going to pick up a couple
