Right shaped steel bar for chuck
bluedog225
Texas
Good morning,
I’ve got a Milwaukee super hog. I love the thing. Lots of grunt.
I’d like to have a steel bar welded to an earth auger (female attachment point) so that I can use the hog to auger some holes in the ground. It’s got half-inch chuck on it.
What’s the right shape piece of steel that would set well in the chuck? Would a simple square piece work? Or do I need something octagonal? Given that it’s a half-inch chuck, I’m guessing anything with a diameter of half inch or less will fit.
I haven’t paid much attention to drill chuck up to this point but I know some of you are experts.
thanks
whateg01
doo dah, kansas, usa
Doesn't it have a standard 3 jaw drill chuck? So a multiple of 3 would work. Like 3. Or 6. If you do 6 sides, 7/16 is the biggest dimension across the flats that is likely to fit.
bluedog225
Texas
OK, I was afraid I was going to get a question. I’ll go look at it next time. I’m up there and report back. If three jaw is the standard, I suspect that’s what it has.
Thanks
dnschmidt
Phoenix, AZ
Got to be a trick question. Every drill I've ever used in my lifetime has had a three jaw chuck and I'm 72 years old. Comon'man. The correct answer is a hexagon.
PCustoms
VT
Weld a giant nut to the auger, use a hex to socket adapter in the drill.
bluedog225
Texas
Something like this? Or a cut off 1/2 Allen wrench may be cheaper.
I’ll need to figure out the dimensions across the flats.
GeoBruin
Wait, you don't have an independently adjustable 4-jaw chuck on your mud mixer/auger drill?
cmandp
New Jersey
That's not going to work for 2 reasons.
1/2" hex (across flats dimension) likely won't fit in your chuck. The circumscribed circle is 0.577". You could turn down the points of the hex to fit but you need a lathe for that.
And second 12L14 steel is not a good alloy to weld.
The largest common size hexagon you can fit in a 1/2" chuck is 7/16" as someone mentioned. I'd look for 1018.
BTW how big of an auger (diameter) are you planning here?
What size holes do you envision drilling into the ground?
Been wondering that since post one, glad you guys stepped up to ask. I've never tried anything bigger than a 1-1/2" wood auger on my MKE right angle drill, which had no problem with it. I suspect 4" or so will start to get questionable, depending on the soil.
MLW ran a 2±# on a DeWalt cordless in our yard to plant bulbs.
cvairwerks
Within hearing distance of Texas Motor Speedway
Probably better off adapting an electric pipe threader to the auger. You need torque at low speeds. Ground augers need low speeds, unless you have it hung off a tractor or skid steer... I've seen a two many auger with a 4" diameter drill on it, throw a couple of 200#+ guys when it got bound up momentarily.
bluedog225
Texas
It’s a 6’’ auger. I agree, it‘s probably too big. Clay and sandy clay.
The tool is pretty good at low speeds. Though it will happily throw you off the ladder. I’ve drilled about 50 three inch holes in singe or double LVL so far.
I wouldn’t mind giving this idea a try. Going slow it might work. Or lesson learned.
The other idea is to buy an earth auger in the 2” range and drill pilot holes for the manual auger or post hole digger. Fill with water and give them some time to soften up.
Thanks all.
PCustoms
VT
Setup a camera when you try this.
Too high of a chance to break a wrist, I'll pass. A 6" hole saw catching is enough to hurt, I can't imagine a 6" earth auger in my hands.
Tim in Indiana
Indiana
I have done exactly this with a 4" auger like what is shown in the picture below. The bit was around $30 on Amazon.
I machined a simple adapter that was hex on one end and round with a pin hole to fit in the auger. I used a Dewalt right angle drill like shown above. I had two foot long extensions made from 1/2" steel pipe and couplings.
The longest I've had to auger was around six foot under a sidewalk to run a water line and 3" pvc drain. Dug down about 3-1/2 feet with the hoe at the beginning and end and ran the auger through.
Nothing difficult about it, went very easily and wasn't hard to hold onto. It was in dry clay. The drill is essentially a two foot long dead handle and it has a clutch that will stop it if it binds. Electricians and plumbers run these all day with big hole saws and auger bits.
