Rigid compression fitting
bluedog225
Texas
Can I use this fitting to transition from 2 inch pvc conduit coming out of the ground to rigid metal going up the wall? Or do I need to come up threaded and join with a threaded coupling?
This would be a lot easier if there is not a downside. Do I need to seal the flexible rings inside the fitting with silicone grease or just crank them down?
Thanks
Chuckster in NJ
Hunterdon County NJ
Why not just use a threaded coupling on the GRC and transition to PVC?……… Much better job.
BTW! Is this compression coupling UL listed for the application?
mike93lx
Richmond, VA
Don't worry about sealing it well. Underground conduit will end up with water in it anyway.
I'd do a male threaded terminal end, and then a female.on the rigid. It's mainly a plumbing thing, but don't screw metal into plastic.
bluedog225
Texas
I’d like the additional protection of the rigid metal conduit above ground at this location. I can have a piece cut and through the blank if I need to.
Then screw the plastic into the metal if I’m understanding correctly.
The metal will be above ground by a couple inch s with a good draining slope away from the building. I’ll probably put some steel hat channel over the junction.
yatg
Southern Oregon
That particular coupler is for water.
You can tell by the black rubber gasket and the "restrain pipe" warning.
The pipe has a tendency to work its way out of the coupler.
There are 2" RMC couplers in a similar style.
Norcal
The fitting shown by the OP is a plumbing fitting, hence not a listed product.
bluedog225
Texas
Thanks!
wrong connector OP. thats for plumbing- the FPT to FPT gives it away. female pipe thread to female pipe thread
I dont think youll find an NRTL listed connector that is for transitioning from PVC to rigid, but ive been wrong before...
Bert_
NW Iowa
Just use an female adapter. If you want rigid, I would make the transition below ground. That way there is no exposed plastic.
mike93lx
Richmond, VA
Curious on what's driving the damage concern. Lawnmower? Vehicles?
If it can be hit hard enough to damage the conduit, the connection to pvc will break and/or the connection to the box/lb above will.
Is there a better way to protect like a small bollard or thicker piece of pope as a sleeve?
Oh, and I think those fittings are for plumbing, but I'm not sure.
