mrramsey
So my garage remodel has stalled due to a frozen and ruptured water line monday. Totally wiped out my 1-1/2 year old basement remodel. thankfully insurance is covering it 100%.
Here is my current issue. I have a 30'x4'x78" 'cold' storage area under my front porch. It is a block wall with a concrete slab above. At one time I framed off roughly an 8' section and lined it with 1" foam board just to keep the chill at bay. Well where the break happened water got into the enclosed areas and had to be dried. I am now thinking I want to just insulate that entire area. Bottom of the concrete slab / ceiling then the walls. Do you think I should seal the block with drylok or something before pinning the insulation on? I think I am going to use 2" XPS, tape the seams, foam any gaps to prevent condensation.
