G_P
What exactly is breaking on the aluminum wrenches? As others said, switching to regular iron wrenches may solve your issues. The heavier iron ones will also make a better hammer!
There is NO 300 ft tower . . . . that's made up by OP. It's excuse for his "maintenance" guys not having the right tool for the job.
He's told us several times this is in PLANT environment. No reason that whole slew of proper hammers and prybars can't be in toolboxes around the PLANT. Obviously the company can afford it. I've never heard of Porsche factory handing out 10" aluminum pipe wrenches so "techs" can beat something into submission !!
Likely there IS reason they are using aluminum . . . . so the abuse ruins the tool instead of equipment they are beating on.
I've worked at large plastic injection plant that became certified in QS9000 and we always managed to find right tool for job (even with production demands) and not beat the wrong tool into submission.
Why not just get proper brass or rubber-faced hammers ?? Pry bars are cheap. This is really as simple as getting proper tools for the job!!![]()
Ridgid makes a 10 inch wrench with a hammering in mind. It's called a Rap wrench I believe. I don't know if the extra weight would be enough to make it difficult for pocket carry. Sounds like some small tool pouches with belts/slings would be handy for carrying a slight variety of tools.
I may have a solution to your problems. Check this out. We have a few spread out in the boiler room and mechanical floors at the hospital I work at. As well as the rap wrench mentioned above. https://www.proferred.tools/products/mining-adjustable-wrench-with-hammer
While I was looking for the link I stumbled upon this http://www.aliexpress.com/store/pro...ers-Universal-wrench/1871166_32451795285.html
CNG, the plant that the OP, overkill_19, works at is really huge, think gulf coast refinery scale. Yes the 300 ft towers (ok maybe 240 ft). They make the same raw pellets that were the feedstock to your injection plant. These plant facilities are some of the largest in western Canada.
Just trying to clairify things.
If you have guys working at 300 feet that don't have a belt with pouches or tool holders, I would sure as hell not want to be anywhere underneath them. I work at heights and I carry the tools that are for the job, along with extra gloves, water, a snack, camera, and a lot of times hardware too. Are they climbing stairs, taking an elevator, or ladder?
Don't follow, stay clear. Common problem with falling tools is what we call the "Baby bird" syndrome. Yell "Look Out!" and EVERYONE looks up with their mouths open.Stairs and ladders
Some wear belts ..some don't
That's why we stick with 10 alum it fits perfect in the side leg pocket of our coveralls.
Never had one fall out, but I've probably seen more close calls with guys tools in their belts catching on the cage than anything.
Hence why we never follow anyone up a ladder. Usually it's only one guy per unit anyway.
Or get some lanyards and keep them attached to something. I have some that are stretchy, so they go from like 12" to 24", work really well.
like I said, a management issue. You should have the tools you needs when you need them. Frankly, things shouldn't just break anyway and continued failures is another management issue.Soo you'd rather him drive back to town ... Get the right tool. Go back fix it. Mean while costing the company 100s of thousands because he couldn't think on his feet and fix stuff on the fly. All to save a $47 pipe wrench?? That don't work in our world you don't have time for that. There have been times I've hands literally less then a minute to fix something before we shut down. Which is min $75000 in gas not to mention loss revenue of product which is in the millions per day.
I've kept equipment running with a washer I had in my pocket fudging a limit switch on a door until the instrument tech could come out with right parts just as one example.
So in reality a $47 pipe wrench is nothing ! I'm a believer of right tool for the job when you have a full box at your leisure. But if you have never used a dime as a screw driver then you wont get what I'm saying!
Not trying to be an ***. Why dont the people climbing the towers take the right tools up there.
Like I said, a management issue. You should have the tools you needs when you need them. Frankly, things shouldn't just break anyway and continued failures is another management issue.
Don't concern yourself with the perfectionist crowd. I know guys who work in pulp and paper mills. They are union workers and when its iffy they make a team call on will and will not be done. Of course they try to keep the plant running but when its a safety risk with a huge motor or huge piece of switchgear, ... it may just need to wait. I also work with guys who can make a mistake and trip a power plant unit offline. Human error is understood & life goes on. Just don't make mistakes frequently. There's a difference between the hobby guys who want a perfect garage to work on their cars on the weekend & take them to the show and the production guys who work production/factory and need to keep the plant running...
True dat !
Funny All I was wondering if snap on made a better pipe wrench ....
Not sure why you call me a liar, but I can see all you want is a internet fight....some just have too much time ....sad really!
Please find another thread to bash! I have zero interest in any of your pick a fight Childish ****! It's sad, weak and spineless!
The issue is that many of us work in similar environments and don't have these kinds of problems.
I work in a steel mill on 50+ acres, 21 buildings, dozens of 100' + tall silos, bucket elevators, dust collectors, and so on.
Without exception, anything with a permanent ladder attached, has a rope tied to the railing on top of the piece of equipment. That rope is used to lift tool bags, buckets, and parts.
Our millwrights are trained to take everything they need with them to complete the job. Tool bags are required to have an array of combo wrenches, adjustable wrenches, pliers & cutters, screwdrivers, pry bars, hex wrenches, and a hammer. If the job requires 10 new bolts, you take 15 with you - anything to reduce down time.
Any machine that has a permanent catwalk or is above 10' with a permanently attached ladder has a 5lb sledge hammer and 3' pry bar in place. This amount to hundreds of hammers, but it is well worth it when compared to loss of production.
Other than the hammers, our company only provides specialty tools and consumables (drill bits, grinder discs, etc). I can't speak for all companies, but I know of very few companies that provide tools for their mechanics.
If I understand correctly, you are handing your mechanics expensive pipe wrenches and letting them do with as they please. Therein lies your problem. No brand of tool will withstand the abuse heaped on it by employees who don't own and care for their tools.
My opinion is that you don't need to find a better brand of pipe wrench, you need a change in company policy.
Brian
Your saying a steel mill is the same/similar process as a poly plant?????? I've toured a steel mill buy make zero claim to their process but what I saw it is nothing like poly!
Nope
We don't have mechanics. You guys just don't get it! EVERY process is different. Steel mill, gas, oil, poly, glycol and yes Porsche !
I find it crazy funny hypocritical that you guys care about your tools sooooo much but you want me to hang them out side so they will be rusted and not safe to use in no time!
Snow rain sun wind it very hard on tools ! Well at least I haven't seen too many Porsche mechanics leaving tool boxes out in the weather!!!! Ummmm!
My SnapOn box has a climate controlled house to live in!
You are, unfortunately, wrong. Although products, processes, and equipment from various industries differ, millwrights/industrial mechanics do not. You can move a journeyman from one industry to another with a very short learning curve.
No one has suggested leaving pipe wrenches in the rain
you're being melodramatic. You are being chastised by experienced mechanics who know something is very wrong if you're having to replace pipe wrenches by the dozen. Any machine that has a permanent catwalk or is above 10' with a permanently attached ladder has a 5lb sledge hammer and 3' pry bar in place.
Read thread!!!! Lol your contradicting yourself...
^^^^^^you just agreed with what I've been saying all along!!!
Brian[/QUOTE
I'm not sure I understand your job and/or title. Perhaps you're merely a purchasing agent? Because you sure as hell don't understand preventative maintenance ...
You need to re read thread! I've never said anything about preventive maintenance. I'm a operator....20 years. The wrenches get beat up only when in crisis and trying keep plant running and get product moving. You guys have turned this around to a daily activity !!! Lol it's not. Our maintain group uses proper tools for the job. All I ever said was we make due with what we have when painted into a corner.
We go threw a lot of wrenches but we have 35 guys... We might go threw 2 a year per guy.
You really need to read my posts in thread not all the assumptions !
If the primary cause of pipe wrench failure is from cracking from being used as a hammer, it's a pretty easy fix.
I like those! I think you should post a picture of a destroyed one just to make some guys squirm! Haha.
#54
Ring cages are hell on tool belts. Usually we run tools up in a bucket on a rope after we are up.
I thought snapon one as identical and a waste of money ????
