Rigid owners
freebo86
Guys that have a Rigid Impact driver, with no bit or trying to drive anything if you pull the trigger on the impact - does the unit click/hammer?
Last week I had a bit break off in the socket, after finally dissembling the unit and removing the broken bit off I noticed now if I just pull the trigger on the impact it starts to click/hammer for a bit then stops.
I don't know if it did this before or not so I'm looking to just see if anyone can confirm. Mine is a X4 gen.
CatSplat
Alberta
My X4 impact just spins, no hammering. You may have some debris still caught up in there.
F
freebo86
Might have to take it apart then I guess again.. It does it then stops and appears to be fine, then I reverse the direction and it does it again then stops.
I am curious to know how the hammering works and when it starts like what activates it - wondering if something is activating it by accident.
CatSplat
Alberta
It's activated by a certain amount of force working against the direction of rotation. So if the driver encounters resistance, it kicks in the hammer action.
F
freebo86
At that force would be against the anvil, correct? Wondering if now its a bit low on grease since I had it opened and some of it might of got wiped off etc?
Any special grease go in these or can I just use automotive or lithium grease?
CatSplat
Alberta
Yeah it would presumably be against the anvil. Sorry, I'm not super familiar with its inner workings or grease requirements, but a bit of extra lube in there certainly couldn't hurt anything.
