Rigid pipe threader question
vettex2
Northern Ca.
I just picked this up for 7 bucks.
It says it has a 1/2" die head. NPT I believe.
Is that OD or ID ?
I need to buy a head for a 1"OD pipe to add pipe to a a water spigot.
Do the die heads go by ID or OD?
Anyone got a part no. ?
I've never done household plumbing before so I'm not sure about the terminology. :headscrat
ssdave
Eastern Oregon
They go by a nominal pipe diameter, that is neither inside nor outside dia. This info might help. It appears that you would need a 3/4" die.
Columns are:
Size
Outside Diameter
Inside Diameter
Wall Thickness
Weight per Ft.
Galvanized SCH 40 Pipe-1/8 1/8 in 0.405 in 0.269 in 0.0680 in 0.224 lb
Galvanized SCH 40 Pipe-1/4 1/4 in 0.540 in 0.364 in 0.0880 in 0.424 lb
Galvanized SCH 40 Pipe-3/8 3/8 in 0.675 in 0.493 in 0.0910 in 0.567 lb
Galvanized SCH 40 Pipe-1/2 1/2 in 0.840 in 0.622 in 0.1090 in 0.850 lb
Galvanized SCH 40 Pipe-3/4 3/4 in 1.050 in 0.824 in 0.1130 in 1.13 lb
Galvanized SCH 40 Pipe-1 1 in 1.315 in 1.049 in 0.1330 in 1.678 lb
Galvanized SCH 40 Pipe-1 1/4 1 1/4 in 1.660 in 1.380 in 0.1400 in 2.272 lb
Galvanized SCH 40 Pipe-1 1/2 1 1/2 in 1.900 in 1.610 in 0.1450 in 2.717 lb
Galvanized SCH 40 Pipe-2 2 in 2.375 in 2.067 in 0.1540 in 3.652 lb
Galvanized SCH 40 Pipe-2 1/2 2 1/2 in 2.875 in 2.469 in 0.2030 in 5.793 lb
Galvanized SCH 40 Pipe-3 3 in 3.500 in 3.068 in 0.2160 in 7.575 lb
Galvanized SCH 40 Pipe-3 1/2 3 1/2 in 4.000 in 3.548 in 0.2260 in 9.109 lb
Galvanized SCH 40 Pipe-4 4 in 4.500 in 4.026 in 0.2370 in 10.790 lb
Galvanized SCH 40 Pipe-5 5 in 5.563 in 5.047 in 0.2580 in 14.617 lb
Galvanized SCH 40 Pipe-6 6 in 6.625 in 6.065 in 0.2800 in 18.974 lb
Galvanized SCH 40 Pipe-8 8 in 8.625 in 7.981 in 0.3220 in 28.554 lb
Galvanized SCH 40 Pipe-10 10 in 10.750 in 10.020 in 0.3650 in 40.483 lb
Galvanized SCH 40 Pipe-11 11 in 11.750 in 11.000 in 0.3750 in 45.557 lb
Galvanized SCH 40 Pipe-12 12 in 12.750 in 12.000 in 0.3750 in 49.562 lb
Galvanized SCH 40 Pipe-12 12 in 12.750 in 12.000 in 0.406 in 53.530 lb
grumpychevy
Indiana
That head is going to thread 1/2" pipe regardless if it is schedule 40 or thicker walled schedule 80. You more than likely need a 3/4" die to do what you want. If you want to make absolutely sure before you spend a decent amount of money on a RIGID die, go to your nearest hardware store in the plumbing department and look at the pipe fittings. NPT stands for National Pipe Thread. By the way, that is a heck of a buy for $20.
LXCam
When calling out for pipe or threading heads that is the ID. 3/4" sch 40 galvi is just a tad over 1". So you need a 3/4" die.
Where are you located at?
V
vettex2
Northern Ca.
I'm in Ca.
I just bought a 3/4" head on ebay
35 bucks incl. shipping.
I'm sorry, the purchase price was 7 bucks, I bought it at a local online auction
I had the price mixed up with another purchase. :confused:
Some WD4- and elbow grease and it will look much better.
It does work fine as is though. Smooth actuation.:thumbup:
Thanks to all for the info.
I'm making some extensions for my hose bibs. The house came with 80+ feet of pipe. Who ever built the place had a lot left over.
They must have been short because all the outside hose spigots are about 1 foot high. :(
I guess I could have had the pipes threaded cheaper but the tool addiction is strong and I'd rather do things on my terms and on my timetable. :bounce:
LXCam
Well if you're anywhere near riverside and would like access to a pipe threading stand and pony head you're welcome to it. I was going to offer you the die too but you got that handled. ;)
V
vettex2
Northern Ca.
I got the 3/4 head today and it works great!
It's like the one on the far left.
I now have 2 heads and the ratchet all for under 50 bucks.
Now, What's the approx. market value?
V
vettex2
Northern Ca.
So it's a fair deal. Good. Thanks.
It's not real pretty paint wise but it's functional and worked well today.
Now I have to come up with some sort of storage solution.
I don't really want it in any of my tool boxes as it won't get used much after I done plumbing stuff.
For now I just ty-wrapped the heads to the tool and shelved it.
