Have had this washer for about 5 years now, never gave me an ounce of trouble till today. It has a 6hp subaru motor and cat pump if I recall.
I started it up, runs ok. Water is connected and turned on. Its running about 2 mins and I go to spray the wand, bogs down shuts off. I start it back up again, does same thing, go to pull it again and its hard to pull??
Remove plug, check for water or gas or whatever in cylinder, nothing comes out and easy to pull. Start it up again, hard to pull.. Check oil, oils fine.. Finally get it started and just sitting there running it sounds like **** and a little overflow spigot on the end of the front of the pump begins to spew water out like nuts.
Pumps bad?
Pumps bad?
