http://www.garagejournal.com/forum/showthread.php?t=309431
The first post includes 2 pictures, is this what you are asking about?
sorry best way to attach a double 2x12 rim band to 6x6.s to set trusses on. for pole barn?
The top girder is also sometimes also done like this:
By far the BEST way is to notch the 6x6 so that the 2x12s sit in the notch. Through bolt.
Double 2x12s ? What is the distance between your posts and what is the span for the trusses.
In many areas that would NOT pass inspection depending of the roof code.
Yes, that is very common. It does not mean it is the BEST way to do it.I have yet to see anyone "notch" the rim joist into the posts. They get leveled and spiked to the post.
I agree that double 2x12 may be overkill. If you only use a single, the truss must rest directly on top of the post.Double 2x12" is a bit much, as the purpose of the rim joists isn't to support the roof, but only to keep the posts aligned.
8ft and 28 ft trusses with 1foot overhang.
scissor trusses 4ft oc ?
I have never seen a roll up door on a scissor truss before. Where did you find that?
