“Thank you” That’s it? No way man. I’m assuming you are in Minn. How big is the cabin? How big the room it will be installed in. FYI , the 38 is best in a pretty open space. The 22, my preferred model, fires from 8,200-20,500. I know you are looking at the high fire, but much of your comfort in a modulating appliance comes from how low it will go and the 5000 btu difference in the low end is important. As to location, I always install mine under a window. The 9” clearance to the vent is easy to make and windows are generally kinda dead space from a decorating standpoint, so it works out well. The 38 is an excellent unit. I heat my 1000 ft shop with one, but I always try to use the 22 if possible.
