Ritco flaring tool
bluedog225
Texas
I need/want to get a flaring tool.
For mini split installs (2 or 3) initially. As I plan to redo the flares on the lines. And a good tool to have around.
Is something like this old Ritco going to give me good service or do I need to spring for something modern like the rigid?
Or something else?
Thanks
housewolf
East Texas
It’s the Indian not the arrow applies here. I’m a retired plumber and made a lot of flares early in my career. We (plumbers) don’t flare as many connections as we used to. I once had a rigid tool like you posted, it will reliably give you good flares. The other, not so much, but if you’re willing to keep a close eye on what you’re doing and are prepared to cut off and redo a flare, you can get by with it. Make sure the tubing is properly reamed after you cut it, position it properly and clamp it tight in the block, you’ll rarely have a bad flare.
When I did my mini splits I used my mastercool that I bought for brake, trans, and fuel lines. It repeatedly makes very good flares but I wouldn’t buy something like that for a few ref flares.
How important those flares are for you depends somewhat on your test/startup procedure. If you’re going to risk losing refrigerant over it, I’d buy the best tool I could afford (justify). If the flares are easy to get to, you’re testing with N2 and pulling a good vacuum, I might roll the dice. Flare connections aren’t particularly problematic.
jsaw
Geneva, N.Y.
The Ritco will work, but the Rigid will work better, and be more enjoyable to work with, due to the way the dies are clamped together. The Ritco style I have found that I have to crank the thumb nuts very tight in order for the tubing to not slip through the dies.
slowtwitch73
Hellgate
Those Ritcos ****... they are usually bowed in the middle no matter how tight the wingnuts are and the line will just push through when you crank the flare down, so u have to clamp it with a c clamp or something which gets in the way of the flare.
My Old Tools
Hamrick Lake, TX
The Ritco will work. If you have trouble with it slipping, put a C clamp or a pair of vise grips in the middle to tighten it up. Obviously, the Rigid is a better tool. but i have flared stainless steel fuel lines with the cheapies. A drop of oil on the tip of the pusher helps.
