RJ's Progressive Air Piping Thread
O
OccupantRJ
Eastern North Carolina
I was reading that article as I'm about to start figuring out my air setup. I noticed this at the bottom of the document and was curious if you guys agreed with it, as I was thinking copper or something like rapid air.
-Clint
If I was to do my system over, I would likely use copper due to it being less physical work. It gets pretty tiring threading and tightening pipe. I already had everything in my case on hand except for the pipe sections and some unions. The Rapid Air would likely be the easier route for most people.
MattT
In 30 years working with a mix of black & galv systems I've seen a lot of filters and tool inlet screens plugged with rust on black iron systems. Never seen any problems caused by zinc flakes.................
Regards copper its relative weakness could be a problem in a shop with employees or a careless shop owner. The joints blowing apart is likely poor workmanship. If you're concerned about the strength of properly made joints you could use Harris Stay Brite instead of regular plumbing solder. It's HVAC rated so good for over double the pressure of a shop air system.
O
OccupantRJ
Here are some current pictures of the air system and shop as of last week. There are 3 ceiling mounted air hose reels and flex hose, as well as two outlets on the shop exterior and piping run to my power equipment and storage building for tires and such.IMG_1716.jpegIMG_1700.jpegIMG_1699.jpegIMG_1704.jpegIMG_1712.jpegIMG_3718.png
