Rockwell belt sander questions
J
jabberwoki
puyallup wa usa
Ok the questions, first what sander belt length do i need and my tensioner is just flopping about ?
Do i just tighten it up when its in position?
J
jabberwoki
puyallup wa usa
ah there's a spring on the arm that the idler arm (item 12) bolts to but that arm it self flops about loose?
there`s no mention in the instructions about adjusting the idler arm?
tool_scrounge
Southern California
What do you mean by "adjusting the idler arm"? There is adjustment for tracking which tilts the large idler wheel relative to the idler arm slightly left or right (when facing the front of the machine) to so the belt is centered on the platen (#29).
tool_scrounge
Southern California
Do you think the whole problem is the idler arm with the small 2" wheel is positioned so far back it prevents the main overarm with the 3" wheel from engaging the belt tensioning spring? if so, the idler arm just needs to be re-positioned as shown below.
J
jabberwoki
puyallup wa usa
I think you answered my question.
Looks like you have to "set" the idler arm in position then tighten it. mine is just really loose.
RJS
That idler arm isn't engaged in normal use. It's used with a second small idler wheel under the table for an alternate belt routing to sand the inside of objects with a hole in them. I'll grab a picture on lunch break, it'll be much easier than trying to explain it.
RJS
Normal operation:
Alternative routing:
You just run the belt through the hole in whatever you're sanding before you hook it over the lower pulley. May want to remove the platen as well, I didn't for a quick picture.
