Rockwell bench top drill press
R_Holiday
North Carolina
What do you guys think about this drill press? I looked through some other threads but couldn’t find any info on a press that looked like this one. The name plate is missing most of the pertinent info other than the name. Thanks in advance
karoc
Hemphill Tx
Myself, I would have that Rockwell than lot of new DP's. No longer made but if it works now it will work from now on unless its been drop or beat to death. Rockwell during its prime sold lot of Rockwell equipment to professionals, hobbyist, and school district which is where I work at. Lot people will say replace the bearing, but I think that is said just make new owner fe el good. If it runs smooth or if there is noise check see if its the motor or not. Over the yrs I have gone through Rockwells table saws, several of their bandsaws, belt sanders but never really did a DP but there is not much to them. So if price is right and it runs as it should then thats a good find. Or if your into restoration projects that will be good one. Join owwm.org its free and that website is devoted to old American made machines where parts do come up for sale.
cmandp
New Jersey
I believe we have a newer version of that drill press at work. It's quite a sturdy drill press for the size. I believe it's 5 speeds.
I would go for it if I didn't already have a drill press and felt like going through it to make sure it's ready to use. I don't feel $75 is out of line either if it runs as it sits.
R
R_Holiday
North Carolina
Thanks for the advice. If it runs as smooth as he says I’ll go ahead and get it. I’ll go ahead and join that site as well.
Jack Olsen
Los Angeles
This site has a catalog of serial numbers so you can see what year yours was made.
http://wiki.vintagemachinery.org/DeltaSerialNumbers.ashx
My 1973 model started out like this:
I cleaned it up and made it into a desktop model by cutting the pillar.
R
R_Holiday
North Carolina
That looks awesome. I don’t know if I’ll be able to find a serial number on it with the tag so beat up. I was gonna try to date it by seeing another press of theirs that uses a similar on off switch in lieu of the button like yours
Whitworth
15" drill press. Probably 1970's.
$75, no brainer. Stop talking about it and go get it.
tool_scrounge
Southern California
The peace sign logo was used in the US starting in 1973. So it was made after that date.
The one thing I would look for on this particular model is angular slop between the spindle and the spindle pulley. I have seen other Delta drill presses of this vintage and model with excess wear on the spindle pulley spline parts.
To test, open the pulley cover. Hold the spindle pulley stationary with one hand. With the other hand, twist the bottom of the drill chuck back and forth (not the moving collar). If needed, bring a L allen Wrench to chuck up in the drill chuck as a handle. If the chuck can be twisted back and forth a lot relative to the pulley, it has a lot of wear. It should have very little slop.
lafester
Northern CO
The table alone is worth more then $75, so you have nothing to lose if for some reason it is not usable. I would definitely grab it.
R
R_Holiday
North Carolina
Did just that. Ended up getting it for $60. Doesn’t have a key for the chuck but I’m sure that can be easily sourced. It ran smooth and has 5 speeds. I’m gonna have to find out the speeds and place it on a card. I was able to make out the serial number and it dates to 1977. It feels solid and is heavy AF; especially compared to the craftsman I picked up yesterday. I’ll check for slop as Scrounge mentioned later on tonight.
