Rockwell Delta 6x48 sander restoration and modification
RSwannabe
I've been on a bit of a quest for a good belt grinder recently. I've got a multitool 2x36 unit attached to a Baldor 7307 1/2hp grinder that I restored, and it is good (https://www.garagejournal.com/forum...grinder-version-awesome.555837/#post-11612797).
I also restored a 10" Baldor Grinder and a vintage Atlas 5010 grinder and combined them together (https://www.garagejournal.com/forum...ration-and-modification.557217/#post-11613921). I tried a Grizzly G1276 belt disc combo, but I didn't like the large footprint or the belt tracking adjustment (relies on a spring for generating tension and it was not consistent, resulting in the belt chewing into the side covers).
I really liked the build quality and the belt tracking of the Atlas 5010, but the 3.25" diameter drive wheel makes it hard to get it up to the higher feed speeds of 5,000+ surface feet per minute (SFPM) optimal for metal grinding. So I thought a Rockwell Delta 6x48 belt sander might be the right tool to suite my needs given its larger drive wheel (5.5" diameter), positive belt tension and tracking adjustment like the Atlas, and solid cast iron build quality. I missed out on a Delta for $150 locally, but it was also missing the side and top covers and some other parts, which are available, but not cheap to replace. I put out feelers on a local metal worker list serve I'm on and found a complete one local to me for a fair price (I actually paid the seller more than he was asking). It was an ex Boeing tool (not uncommon in the Seattle area) with a 1979 build date going from the serial number.
My original plan was to try mounting it to a Baldor 10" buffer not unlike what I did with the Atlas. On a 3600 rpm buffer, the belt on the Delta 6x48 sander would be running just under 5,200 SFPM. Unfortunately the bigger Baldor buffers are less common than the grinders and cost more money. I was not able to find a good deal on a 10" buffer (1.5 hp and 3,600 rpm), so I considered using the sander as it was intended on a base with a motor and drive belt. I had a sheet metal stand with 1hp motor that my sander came with, but I was not a fan of the floor space it took up or the aesthetics of it.
R
RSwannabe
In looking into other options for mounting the Delta belt sander, I came across the old optional cast iron art deco bases that were offered for the Rockwell Delta machinery. I love old machinery and I love good art deco, so this was right up my alley. To say I was smitten would be an understatement.
I set up a search, not expecting to find anything soon, but within a week a jointer with the cast iron art deco base (same base as used with the sander) popped up on Offer up an hour from me. I picked it up for $200 and cleaned up and resold the jointer by itself for $100. I then got to restoring the sander and the base.
R
RSwannabe
So then I disassembled the sander and the base, replaced all bearings with new, cleaned, primed and painted. I cleaned up the hardwared with a wire wheel and a 3m soft deburring wheel. The soft deburring wheel is fantastic for stripping old paint and getting a bright finish.
Here is the test fit of the sander base on the art deco stand.
Strip down.
I have a high confidence this will be a permanent addition to my shop, so I went ahead and repainted it in Rustoleum Sunrise Red, the official color of my shop.
Painted Parts
Base reassembly.
Sander Assembly.
R
RSwannabe
Mating sander to base to check alignment for motor position. Its coming together!
I'm planning to run a Baldor 2hp 3 phase motor I picked up for $50. I pulled apart the motor, cleaned it, installed new bearings, and repainted it in Rustoleum Smoke Grey.
hampster
That looks nice! Neat that you were able to find the base, that can be tough. I did the same thing with a delta bandsaw I bought... It was lacking the base but I happened to spot a broken jointer at an auction for $25 that included the correct base.
