Soccer918843
So I’ve finished insulating all my walls and applied a 6 mil vapor barrier question is do I install a vapor barrier to the ceiling too or no a lot of people say no so that it can breath.?
Went both directions r23 between the bottom cord of the trusses then r30 going the other direction.Damn! R53 I didn’t even know rockwool made anything that big that must of weighed a ton your building is gonna be super efficent I bet I used r 30 in my ceiling and r23 in the walls
Take a look at this, based on what you have said for a description of the space yes you should be using a vapor barrier behind your ceiling sheathing. There are lots of good resources for this stuff around this is just one spot.
https://www.jlconline.com/how-to/insulation/q-a-ceiling-vapor-barrier-yes-or-no_o
You could also call your local building permit people and ask about local requirements.
Sent from my SM-G960W using The Garage Journal mobile app
