ford33
You do excellent work. That trailer is awesome.
The fender design is nice too.
I took a quick video on my cell phone of the trailer in action. The video doesn't do it justice, so when the trailer and the bin 100% done I'm going to buy a GoPro (or a knock off) and Ill make a good video with multiple camera angles.
looks cool, I am curious about a couple things, what is the working load limit of the cable on the winch? and how are you securing the bin to the trailer once it's on there? it looks like if the cable breaks the bin could possibly come off.
not knocking your project, just wondering
I don't know what the working load limit is on the cable but its should be a minimum 1.5x the winches max pulling force of 12k lbs so probably be 18,000 lbs if not more.
please check into it, my wrecker has a 12k lb winch on it (as do most tow trucks), the wll on the cable is typically around 3500 to 4k lbs. to safely pull more that that a ****** block is used to double the capacity. also pulling up at the angle you look like you are plus the weight of the load can put a serious strain on a cable.
again, I'm not trying to insult your intelligence.... I just don't want to see anyone get hurt.![]()
Did you do a build thread for the 6x10?
Am i missing it?
Looking good!
What is your plan for dumping the bin on the trailer? It looks like the rear frame rails will get in the way of whatever is getting dumped out the back of the bin.
Or is your plan to use the winch to slide the bin back first, then open the gate to dump the contents?
I just did this on another thread, but it applies here as well.![]()
to not overwork the bowing guy. Wow! I really like the flatbed setup! Very nice!
Great job again.
What type of trailer are you going to build next? I mean, when your bored with this one.
The roll off setup is pretty damn handy, maybe a hooklift.....
Its been a while since I built the trailer but I spent several weeks in total building everything. I don't remember how much it cost me but I would guess it was $5-10k. A roll off trailer is worth it if you want to have multiple bins and have a HD truck to tow it around with. I ended up selling the trailer and went back to a flatbed and a dump trailer. The two reasons I sold the trailer was it was to heavy for my truck and in my province I had to get annual safety's on the truck and trailer which I didn't want to deal with for a trailer I only used a few times a year. The main thing I hated about a roll off was it was difficult to line the bin up to the trailer since you have multiple articulation points and you can't see the rails in your mirrors. If I were ever to build on again I would build a hook lift since you can still load them if your not aligned straight.I realize this is an old thread, but i'll ask anyhow. I remember seeing your video on youtube some years ago and its since been stuck in the back off my head, as i appreciated the quality of work that had gone into it. Today i was interested in the subject of roll off trailers again and was lucky enough to stumble onto this forum to get a closer look at how you put the thing together. I've spent quite a bit of time pausing and zooming in on your video to get a better look. I opened this account so i can actually get a good look at your pictures.
So ill ask this: - How many hours do you have into this project?
- About how much $ did you spend on it?
-Is it worth building to replace the need for two trailers?
Ive the idea of building a goosneck set up with around a 20ft bed, 3 7K axles so i can comfortably haul equipment, and build the rails to the roll off industry standard. I have a small excavator i run on the side that the dump would be handy for, and like the idea of dumpsters as a more passive income. Also am always hauling equipment / steel / industrial tools.
Some tidy work for a bricklayer! haha
Nice, thanks for your reply. Im with you on the hooklift. The only restriction i can see there is you would add a fair deal of weight with a hooklift system, which would cut into your payload. It may be negligible though, depending on how its constructed.Its been a while since I built the trailer but I spent several weeks in total building everything. I don't remember how much it cost me but I would guess it was $5-10k. A roll off trailer is worth it if you want to have multiple bins and have a HD truck to tow it around with. I ended up selling the trailer and went back to a flatbed and a dump trailer. The two reasons I sold the trailer was it was to heavy for my truck and in my province I had to get annual safety's on the truck and trailer which I didn't want to deal with for a trailer I only used a few times a year. The main thing I hated about a roll off was it was difficult to line the bin up to the trailer since you have multiple articulation points and you can't see the rails in your mirrors. If I were ever to build on again I would build a hook lift since you can still load them if your not aligned straight.
