Roll pin sizing question.
jptbay
Trying to fix the shifter in my plow truck.
Roll pin is missing from the 3-4 shift rail in the shift tower.
Measured the hole with a transfer punch. It's 7/32".
My stupid question is: Is a 7/32 sized roll pin meant to fit tightly in 7/32" hole?
Thanks all. :eyecrazy:
J
jptbay
Thanks.
By that chart, a 7/32 roll pin should do the trick.
leg17
Kentucky
That's the point of them.
The hole need not be precisely reamed, as for a normal dowel pin, but can be simply be drilled nominally and the same size roll pin, (technically spring pin), can be used.
ChevyEFI
Phoenix, AZ
To your question, yes.
The ones I use most are 3/16".
A drill that size fits the hole nicely.
And the roll pins are considered 3/16" in size.
Spirols are indeed nice.
Provincial
Near Salem, OR
If you are concerned about the pin falling out again, use a piece of safety wire through the hole in the center of the pin and around the shaft. That way it can't fall out.
J
jptbay
Thanks again for the tips. Might try the safety wire. Was considering using some green Loctite 680 retaining compound on this pin.
merr6267
Ravenna, MI
Loctite may or may not help you in the instance of a shift rail.
Retaining compound is generally for something that does not have motion between pieces. I'm not saying that it can't help, but I'd look at mechanical means too.
The "split pin" or "roll pin" will flex by very small increments with each strong shift. There is a spring to the fitment of the pin and with a strong shift the pin will shift very slightly and then return to form. THe retaining compound may eventually stop bonding with the bores as the spring pin flexes. The method of retention for these types of fasteners is due to the springy nature of the pin. They are chosen because they are forgiving of differences in bore and shape of the bore. If you were to try to use a solid dowel, you'd need a precision reamed bore and you'd have a very tight press fit.
If you can find them, true "roll pins" will be stronger than simple and more common "split pins" or "spring pins". See the illustration below.
http://www.mcmaster.com/#roll-pins/=10y8md0
The safety wire suggestion is great! Even just a simple loop through the center of the pin and tighly coiled around the fork and rail should do the trick.
good luck!
PM
J
jptbay
Ordered up some coiled spring pins. Thanks for the McMaster-Carr link.
merr6267
Ravenna, MI
No problem. Good luck with the project. My plow truck is sitting and waiting for some snow . . . Mud season came early. Not that I'm disappointed with that.
