AffableCurmudgeon
I have a house with an attached garage. It is fed by a 15 amp circuit. I would like to add a 40 amp panel in the garage. I would feed a 240 outlet and a few 120 outlets from the new garage panel.
The current setup is this:
1. The 200 amp service disconnect is in a panel outside the house. The breaker is the only thing in that panel.
2. That outside panel feeds a second panel in the laundry room. That panel does not have master breaker. It only has individual breakers that feed the first floor living areas, garage and outside outlets and lights. The laundry room panel also has a 40 amp dual breaker that feeds a third panel on the second floor.
3. The second floor panel has breakers that feed upstairs living areas.
The garage wall where I would like to put the new 40 amp panel is less than 15 feet away from the first floor laundry room panel if I go down the wall from the panel and through the crawl space.
With all that, I have some questions:
1. Can I use 8-3 Romex to go from the laundry room panel to the garage through the crawl space?
2. Would I need PVC conduit in the wall and in the crawl space?
3. I would like to have a 40 amp disconnect in the new garage panel. Would I need a 40 amp breaker in the laundry room panel that would feed the garage panel as well?
4. What would be a better approach?
Thanks.
Thanks.
