bobinyelm
With regard to residential wiring (in a garage), It's apparently "legal" to run Romex NMC through PVC conduit for "physical protection" in places where it might be damaged (below 8ft height in garages or shops, for instance).
But where one needs to run wiring externally around corners and it needs physical protection, can it be enclosed in flexible armor (plastic or metal).
They obviously sell "BX" type armor and flexible conduit in various diameters, but is it ONLY OK to use individual pulled wires in it, then transition to NMC in a junction box (when in an area physical protection is not required) and continue with NMC, or alternatively wire the whole building using individual wires and use conduit or armor for the installation? Or can a portion of armor be slipped over the Romex (properly terminated at each end) to protect the NMC where it is exposed to damage?
This is in an older (1945) home where a new 240v circuit is being run to the attached garage. There is already an armored cable that was previously installed and certified (inspected and has a city inspection placard posted) that is surface mounted leading from the panel to a drier outlet. The new circuit would be run right next to the existing armored cable, and extend to the adjoining garage.
has been beaten many times on here.
