Romex staples for older, harder lumber?
gatorgrabber
Gainesville, FL
I'm remodeling a 70's Florida home and the pine/fir 2x4's are quite solid. This is a good thing until it comes time to drive Romex staples to secure new wiring. The standard staples you hammer in are a bit of a challenge, so I decided to try the DeWalt 20v cable stapler. Wow, that was a mistake! Only 1 out of 5 staples actually penetrated the lumber, and then, just barely. It was like driving them into concrete! It worked fine on new, softer lumber but was a hard fail for my home, so back it went. So my question is what method do you professionals out there use for this situation? I have around 500' of Romex that needs to be secured, so I'm a bit motivated to find an answer. If it was just for a few areas, I'd just drill pilot holes for the staple and call it a day. Unfortunately, that's not the case. :dunno:
What I'm currently using that does work are the GB NM staples (for masonry work) that use a nail on each side of the insulator to secure them. My concern is that the nails are not all that long. Any better ideas?
Thanks!
Crazyjake8493
Upstate NY
When I've run into really hard old joists I use the the staples with a nail on each side. Overall I'm not a fan of them, but on hard lumber it's easier to drive one nail at a time in straight, whereas traditional Romex staples want to twist.
Another option (more expensive) would be Romex straps and nails or screws.
Terry D
St. Louis, MO.
The ones from Home Depot and Lowes, the GB brand are junk. Get the " Theil " brand. You might have to go to a supply house, but are much better.
G
gatorgrabber
Gainesville, FL
Thanks for the options! I'll head over to the supply house tomorrow and grab some Thiel staples and some Romex straps. Between the two, I should have this covered. I appreciate the help!
u2slow
BC
Same here. I use both for hard lumber. Prefer things with screws though... zero waste if I change my mind.
nadogail
Coronado, CA
Is there a staple driving tool where the staple is held straight in the tool and you hammer a plunger; sort of like a floor nailer?
Chuckster in NJ
Hunterdon County NJ
Hold the staple with a pair of linesman pliers and hit that mofo!....... Helps to have a quality staple as mentioned in post #4.
BTW! A good electrical supply house is your best friend!
