Roof Boot question
35k0
Minnesota
Hi Guys,
I built a sauna a little over a year ago, but I am changing things up and I need to move the stove.
I will need to put a new hole through the roof, so I need a new sheet of metal roofing and then I need to put the stove pipe through the new location.
This is the stove pipe boot I used for the Class A stove pipe
Maybe it will be less hassle to just get a new boot?
I don't want to buy another one if I don't have to, do you think it will be difficult to clean it up to install in the new location?
If anyone cares as to why I am making changes, I initially wanted the stove closer to the window that you can kind of see to the right, but was afraid it might wreak havoc on the glass, (it's the stationary window from an Anderson sliding glass door turned sideways) but after talking with others that have done the same, I am going to move ahead with this and then build benches along the wall where the stove was.
Current setup with only two high benches, which isn't ideal, but works.
New plan
Mr onetwo
Coastal Maine
Why don't you just remove the whole sheet containing the boot and then cut it down to fit the new location.Just install it like a big roof shingle.
PCustoms
VT
How much are you actually moving the stove?
Add a couple 45's inside
