What type of roofing material - metal? What type of framing/rafters? Low pitch roof with no attic space or gable style with attic space? Location?
I hired a roofing contractor to install a standing seam metal roof on our house. He specializes in metal roofing only and does it for all types of buildings - residential, institutional & commercial. I had the roof built with 2x4 purlins and not plywood or OSB. The contractor put down a layer of heavy roof felt everywhere as a thermal break to prevent/minimize condensation. We live in the PNW with high humidity levels for extended periods and condensation has never been an issue.
Need to be careful not to tear it when putting on the roof. Because of the tar in it, you can't fix it with any sort of tape because it just won't stick.
It's every important to have the roof assembly properly vented to code for the specific location where the structure is. Must be a vented air space between insulation and roof deck (except for spray foam).
