Roof Decking???
karoc
Hemphill Tx
OSB or CDX 19/32? While prices seems cheaper now than month ago, I need pull trigger on 90 sheets.
Synthetic underlayment w/ metal roof, if I can afford it
mike93lx
Richmond, VA
Make sure you get a quote on that qty and don't just go off the sticker price on tbe shelf. If buying from HD, the prodesk will quote it and likely give a sizable discount.
K
karoc
Hemphill Tx
Does it not have a dipstick ?
I changed the fluid and filter in my '08 F150, almost absolutely positive I did.
Fantastic, did not know that. Thanks for passing that info
Bill T
Easley,S.C.
It may be a little off topic, but, which ever you choose (I use 5/8CDX) make sure you install it so you can see the grade stamp from insie the building. I had an over-vealous Building Inspector. Before he would signoff on shop, he checked the grade stamps. His comment" Boy, you sure are lucky you turned all the sheathing so I could see the grade stamp".
