One thing that I would do (I was trained to do this as standard practice when using an extension ladder) is that after you have the ladder extended to the height that you need it before climbing the ladder use the rope that you extend the ladder with to tie the top and bottom sections of the ladder together, I was trained to do this by having the rope continue down the back of the ladder and under a lower rung on the bottom section of the ladder and then taking the end up the front side of the ladder and wrapping it around the bottom rung of the fly section and the corresponding rung of the bottom section three or four times then tieing some half hitches around the rope in the front and the back of the ladder just above the rungs you wrapped, it does mean that the rope is running up the middle of the ladder but once you are used to that it won't be a problem. That way when you hang your ladder off your hooks there would be no way the bottom could slide out even if you didn't tie it off to your eyebolt. I hope you can understand my description of how to do this, it's easier done than explained.
Great idea about tying the ladder together at the rungs. I get the idea and I'm trying to accomplish the same thing with the eyebolt. My thinking was that if I, for some reason leaned on my ladder extensions at the top the bottom of the ladder would lift up and slide out of the locks that hold the two sections together. We're all on the same track here..............
Thanks for the comments and feedback............ Much appreciated.
Lisa
