pavementpolisher
Hi Guys...
I have been researching on here for the last month looking at different options for a building I want to build. I have found TONS of great info and some great ideas, but I have searched for the last two hours and cannot find someone in my same situation.
I am going to build a 40x40x14 to be used as a cold storage building for our RV and boat, and tractor. Then in next 5-10 years I will build another 40x60 attached and turn this 40x40 into my workshop when we build our house.
I am trying to decide whether or not to do roof insulation right now if I am going to be putting a steel ceiling in when I finish off the inside eventually.
Building Plans:
40x40x14, Pole Barn Style, Steel Roof, gravel floor (for now), 12" vented overhangs Being built in Michigan only used for storage, (no heat)
Future:
Steel ceiling, (blown in insulation above steel) Plan is spray foam walls, probably radiant heat in floor. Concrete, etc. etc.
Question-
Should I put the "double bubble" type insulation between metal roof and rafters now if this will be just a storage building? I don't mind paying the $700 extra now if it will help for the future. But I am thinking if I am going to be putting a ceiling up the insulation in the roof will not help as much?
I found lots of good info for insulation ideas, but nobody in my same situation. If this has been covered please point me in the right direction
Thanks in advance.
Aaron
Building Plans:
Future:
Question-
Thanks in advance.
Aaron
